[OpenLayers-Users] Proxy problem in GetFeatureInfo - nosolution??
Barend Köbben kobben at itc.nl
Mon Mar 29 02:39:53 EDT 2010
Your BBOx is wrong
BBOX=70.4375 17.5375 76.0625 23.1625
Should read
BBOX=70.4375,17.5375,76.0625,23.1625
(with commas iso. Spaces, plus you are missing a coordinate).
Barend Köbben
Senior Lecturer
ITC ­ University of Twente, Faculty of Geo-Information Science and
Earth Observation
PO Box 6, 7500AA Enschede, The Netherlands
+31 (0)53 4874253
On 28-03-10 21:30, "sunny74" <sb.ray at hotmail.com> wrote:
> Hi David,
> Thanks for your reply.
> You are right.
> When I issue command directly i browser in IE I get download dialog which I
> can save as .txt or .html.
> I saved it and I got the message "msWMSLoadGetMapParams(); Wms Server error.
> Wrong number of arguments for BBOX.
> When I run the program that calls init2() function I get the error
> msWMSFeatureInfo();WMS Server error; Unsupported INFO_FORMAT
> value(text/html).
> Why does OpenLayers.loadUrl(url, '', this, setHTML); not work at all?
> It doesn't give any output whatsoever.
> How can I make it work?
> The header, template and footer files are all blank.Should it be like this
> or do I need to put the structure of the attribute list in there?
> Thanks again.
> http://n2.nabble.com/Proxy-problem-in-GetFeatureInfo-no-solution-tp4802810p481
> 4418.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Faculty of Geo-Information Science and Earth Observation (ITC)
E-mail disclaimer
The information in this e-mail, including any attachments, is intended for the addressee only. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or action in relation to the content of this information is strictly prohibited. If you have received this e-mail by mistake, please delete the message and any attachment and inform the sender by return e-mail. ITC accepts no liability for any error or omission in the message content or for damage of any kind that may arise as a result of e-mail transmission.
