[OpenLayers-Users] SelectFeature on Overlapping Layers
Afroz Kannancheri afrozk at gmail.com
Mon May 3 11:56:08 EDT 2010
  Coulnt find a solution with the vector layers nd I dint continue trying as
the vector layers were giving me other problems as well.
I changed my two layers to WMS layers and then found a workaround by making
the featurecount as 2 and parsing the result
Thanks
Afroz Kannancheri
On Mon, May 3, 2010 at 4:39 PM, mortac8 [via OSGeo.org] <
ml-node+4997561-266906357-382940 at n2.nabble.com<ml-node%2B4997561-266906357-382940 at n2.nabble.com>
> wrote:
> Did you ever find a solution for this?  I am looking for a way to set a
> "top" layer so that if data from different layers overlap, the data on my
> "top" layer gets selected.
>  Afroz Kannancheri wrote:
> Thanx for the replies,
>             What I expect is to get the data for the polygon on Layer2
> hidden below the polygon on Layer1.
> I donno how to iterate and check if theres an intersection and get data if
> thers an intersection.
> Did some research on this before replying but failed.
> Please shed some light on this.
> Thanks
> Afroz
> View message @
> http://osgeo-org.1803224.n2.nabble.com/SelectFeature-on-Overlapping-Layers-tp4412919p4997561.html
> To unsubscribe from Re: SelectFeature on Overlapping Layers, click here<http://osgeo-org.1803224.n2.nabble.com/subscriptions/Unsubscribe.jtp?code=YWZyb3prQGdtYWlsLmNvbXw0NDE4NjI0fDEyODgxMDE2NA==>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SelectFeature-on-Overlapping-Layers-tp4412919p4998540.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100503/55d89f41/attachment.html
