[OpenLayers-Users] measure layer
bartvde at osgis.nl bartvde at osgis.nl
Tue May 4 04:54:05 EDT 2010
I think you need to create your own vector layer, and then listen to the
measure event. In the event handler you can create a feature using the
geometry returned and add it to your layer.
Best regards,
Bart
> Hi all,
> using measure control, after I have drawn a line (or polygon) I get the
> relative value for length (or area), and then,  if I make a new measure
> drawing a new line, the previous one disappear.
> I would like to have instead a "mesure layer" that allow to make multiple
> measures, drawing multiple lines each one with a progressive number as
> label.
> What is the best way to get this result?
> Is it possible to make this layer a real layer (turning it on/of)?
> Thanks
> Marco
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
