[OpenLayers-Users] kml-files doesn't shown correct
    Dirk Wimmer
    speleo at web.de
    Wed May  5 17:45:01 EDT 2010
Hello,
I have problem to use this kml file with openlayers:
http://www.dav-felsinfo.de/export/cliffs_kml.php?1=22
E.g. I use this example
http://www.openlayers.org/dev/examples/sundials.html and change only a
little bit:
            var sundials = new OpenLayers.Layer.Vector("KML", {
                projection: map.displayProjection,
                strategies: [new OpenLayers.Strategy.Fixed()],
                protocol: new OpenLayers.Protocol.HTTP({
                    url: "http://www.dav-felsinfo.de/export/cliffs_kml.php?1=22",
                    format: new OpenLayers.Format.KML({
                        extractStyles: true,
                        extractAttributes: true
Then I see only one icon in the sea nearby Africa and not in Germany. :-(
But the result should looks like that:
http://maps.google.de/maps?f=q&hl=de&q=http://www.dav-felsinfo.de/export/cliffs_kml.php?1=22
I try some other kml files and it works.
Could it be that this kml file is incorrect?
Any ideas?
thanks,
Dirk
