[OpenLayers-Users] [OpenLayers-Dev] Can OpenLayers call ......
Stephen Woodbridge woodbri at swoodbridge.com
Fri May 7 00:06:41 EDT 2010
Hi Venkat and Anindya,
First, your questions (see below) are user questions and not dev
questions so I have moved them over to the user list.
Second, your questions are very basic web development questions and not
really OpenLayers specific. OpenLayers is a JavaScript library that runs
in a web browser, so all the rules that apply to this development
environment apply to OpenLayers.
  If you can not answer this question then you need to do more research
and read some tutorials on web development BEFORE you start asking
questions on OpenLayers User or the Dev lists. [2] So questions like,
Can OpenLayers call .... can be more generally ask in terms of can any
JavaScript web client call ... and how do they do that? Then you can
look at the examples OpenLayers provides that do very simple things like
you are asking. Once you have some basic understanding of OpenLayers and
you need to more specific information, I'm sure there are plenty of
people that are willing to give you some help.
If you are asking to decide if you should pursue some additional
investigation on your own then:
1) Yes, OpenLayers can call AJAX services - see the examples [1].
2) Yes, OpenLayers has support for parsing various geostapial data
formats - see the examples [1]
3) No Javascript running in a browser can talk to a Database without
some kind of AJAX server application
4) All Javascript running in a browser can talk to web services as AJAX
requests, but you have to deal with the "server of origin" issues. If
you don't know what that means, google it.
-Steve
[1] http://dev.openlayers.org/releases/OpenLayers-2.9/examples/
[2] http://trac.openlayers.org/wiki/Documentation
-------- Original Message --------
Subject: [OpenLayers-Dev] Can OpenLayers call a webservice?
Date: Thu, 6 May 2010 18:51:23 -0700 (PDT)
To: dev at openlayers.org
I was stuck up at the below implementations and am not able to move further.
I have few queries on OpenLayers functionalities, Please let me know the
possibility of the approach and the best way of implementing it !!
1. Can OpenLayers directly read the XML data with spatial information and
display in web page? If this possible, please give any example
2. Can OpenLayers connect directly to any database (oracle) and publish the
data on map? one way of connecting to the database is through the use of
GeoServer with OpenLayers. But I want to use only OpenLayers to connect to
the oracle database. Please let me know how to achieve this?
3. Can OpenLayers using JavaScript (AJAX) can call a Oracle BPEL webservice?
If so how to customize the openlayers to call the webservice
Regards
Venkat
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Can-OpenLayers-call-a-webservice-tp5017473p5017473.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
Dev mailing list
Dev at openlayers.org
http://openlayers.org/mailman/listinfo/dev
Subject: [OpenLayers-Dev] Can OpenLayers call a java program
Date: Thu, 6 May 2010 19:34:36 -0700 (PDT)
Can OpenLayers call a java program? If yes, can anybody provide any example
which explains how OpenLayers call a java program
Regards,
Anindya
http://osgeo-org.1803224.n2.nabble.com/Can-OpenLayers-call-a-java-program-tp5017563p5017563.html
Dev mailing list
