[OpenLayers-Users] Nodelist Info / GetFeatureInfo not working
Roald de Wit list at rdewit.net
Sun May 9 18:06:52 EDT 2010
Hi Pascal,
You should pretty much always get at least *something* back: either an
error or an empty reponse (FireBug would tell you). Have you really got
":80" in your settings like below?
     OpenLayers.loadURL("http://myownhomepage.xyz:80/geoserver/wms",
params, this, setHTML, setHTML);
If your Tomcat runs on port 80 then you can leave out the port number.
That might do the trick (and yes, it would then have been a proxy
issue). Like this:
     OpenLayers.loadURL("http://myownhomepage.xyz/geoserver/wms
<http://myownhomepage.xyz:80/geoserver/wms>", params, this, setHTML,
setHTML);
And since your OL is on the same server as your GS, you could even do this:
     OpenLayers.loadURL("/geoserver/wms
setHTML);
And to deal with errors in your AJAX request, why not use a separate
function like this:
*onAjaxError*);
Regards, Roald
On 10/05/10 05:45, boxplot wrote:
> Hi,
> maybe a made a small progress. As I have written in my last mail I get
> no response when using GetFeatureInfo (I do get a response when using
> the GeoServer OpenLayers example which I can access through "Layer
> Preview" => see code below). So I copied both requests directly into
> my browser and both got a response:
>> http://myownhomepage.xyz/geoserver/wms?REQUEST=GetFeatureInfo&EXCEPTIONS=application%2Fvnd.ogc.se_xml&BBOX=12.327023%2C47.673%2C12.362977%2C47.777&X=79&Y=375&INFO_FORMAT=text%2Fhtml&QUERY_LAYERS=Workspace%3ALayer&FEATURE_COUNT=50&Srs=EPSG%3A4326&Layers=Workspace%3ALayer&Styles=&WIDTH=177&HEIGHT=512&format=image%2Fpng
>> <http://myownhomepage.xyz/geoserver/wms?REQUEST=GetFeatureInfo&EXCEPTIONS=application%2Fvnd.ogc.se_xml&BBOX=12.327023%2C47.673%2C12.362977%2C47.777&X=79&Y=375&INFO_FORMAT=text%2Fhtml&QUERY_LAYERS=Workspace%3ALayer&FEATURE_COUNT=50&Srs=EPSG%3A4326&Layers=Workspace%3ALayer&Styles=&WIDTH=177&HEIGHT=512&format=image%2Fpng>
> GeoServer runs as a .war within Tomcat and OpenLayers is on the same
> server. I really can't believe why the same code with the same request
> on the same server is once getting a response and the other time it is
> not. Is there a possibility that it is a proxy-issue or maybe a
> problem with the encoding?
> Thanks, Pascal
> Am 09.05.2010 um 01:05 schrieb Roald de Wit:
>> Hi,
>> Have you looked at the request that OL is sending to GS? The FireBug
>> addin for Firefox has a 'Net' tab that shows you every request that
>> your application sends, including what response it gets back.
>> That might help you find out what's wrong.
>> Regards, Roald
