[OpenLayers-Users] ModifyFeature with SelectFeature hover/highlight type capability
Charles Galpin cgalpin at lhsw.com
Mon May 10 13:18:57 EDT 2010
Hi all. I'm new to the list (as well as openlayers) and have some hopefully rudimentary questions.
First, can someone explain or point to an example that shows how to extend ModifyFeature to visually select features as you mouse over them like you can with the SelectFeature? What I want to do is visually highlight them as I mouse over them (as well as display some detail about them in a layer) but not actually select them (ie put into edit mode) until I click on them.  Once they are truly selected I want them to stay highlighted while being edited/moved (I am working with points).
I have tried setting hover = true for the ModifyFeature, as well as create my own SelectFeature and set the modifyFeature.selectControl to it but when I do that, the ModifyFeature behaves like a SelectFeature only.
thanks,
charles
