[OpenLayers-Users] Popup over GPX track
emmexx emmexx at tiscalinet.it
Tue May 11 13:11:37 EDT 2010
Il 11/05/2010 18:43, Francesco scrisse:
> Hi,
>      I'm trying to display a popup on mouse over GPX track. This is the
> code used to load the track:
>                  onSelect: function(feature) {
> --------------> Here I want to display a popup with info from the GPX file
>                  onUnselect: function(feature) {
I use eventListeners instead of onSelect onUnselect.
bye
	maxx
>>> Code for the popup:
	var highlightCtrl = new OpenLayers.Control.SelectFeature([vlayer,
clayer], {
		hover: true,
		highlightOnly: true,
		multiple: true,
		geometryTypes: ["OpenLayers.Geometry.LineString"],
		renderIntent: "temporary",
		eventListeners:
			featurehighlighted: function(f)
				popup = new OpenLayers.Popup("mylayer",
f.feature.geometry.getBounds().getCenterLonLat(),
null,
'some html text',
null,
true);
 				popup.autoSize=true;
// 				popup.panMapIfOutOfView=true;
				f.feature.popup = popup;
				map.addPopup(popup);
			featureunhighlighted: function(f)
            	map.removePopup(f.feature.popup);
            	f.feature.popup.destroy();
            	f.feature.popup = null;
	map.addControl(highlightCtrl);
	highlightCtrl.activate();
(popup is a global variable)
>>>> Code to open a gpx file:
		var tmplayerGps= new OpenLayers.Layer.GML('myfile', path,
				format:  OpenLayers.Format.GPX,
				formatOptions: {
					extractAttributes: true,
					extractStyles: false,
					maxDepth: 2,
					extractTracks: true,
					extractRoutes: false,
					extractWaypoints: false
				'styleMap': styleMap,
				projection: map.displayProjection
