[OpenLayers-Users] Popup over GPX track
Francesco
webfrank at tiscali.it
Mon May 17 04:44:54 EDT 2010
I tried with this code:
var lgpx = new OpenLayers.Layer.Vector("Track", {
style: {strokeColor: 'red', strokeWidth: 10,
strokeOpacity: 0.5},
projection: map.displayProjection,
strategies: [new OpenLayers.Strategy.Fixed()],
protocol: new OpenLayers.Protocol.HTTP({
url: 'gpx.php?imei='+imei+'&from='+from+'&to='+to,
format: new OpenLayers.Format.GPX({
extractAttributes: true,
extractStyles: false,
maxDepth: 4,
extractTracks: true,
extractRoutes: false,
extractWaypoints: false
map.addLayer(lgpx);
lgpx.events.register('loadend',lgpx,function() {
var bounds = this.getDataExtent();
map.zoomToExtent(bounds);
var hoverSelect = new OpenLayers.Control.SelectFeature(lgpx, {
hover: true,
multiple: true,
geometryTypes: ["OpenLayers.Geometry.LineString"],
renderIntent: "temporary",
onSelect: function(f) {
var content = 'popup';
popup = new OpenLayers.Popup.FramedCloud("Info",
f.geometry.getBounds().getCenterLonLat(),
null,
content,
null, true, function() {
hoverSelect.unselectAll();
f.popup = popup;
map.addPopup(popup);
onUnselect: function(f) {
if (f.popup) {
map.removePopup(f.popup);
f.popup.destroy();
delete f.popup;
map.addControl(hoverSelect);
hoverSelect.activate();
and the GPX file is like this:
<gpx xmlns="http://www.topografix.com/GPX/1/1"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.1"
creator="Waze Mobile Ltd (1.4.0.1) -
http://roadmap.digitalomaha.net/editor.html"
xsi:schemaLocation="http://www.topografix.com/GPX/1/1
http://www.topografix.com/GPX/1/1/gpx.xsd">
<trk xmlns="">
<trkseg>
<trkpt lat="37.0617024" lon="14.9067984">
<time>2010-05-16T10:46:10Z</time>
<name>0</name>
</trkpt>
I would like to display inside the popup time and name attributes
Il 11/05/2010 19.11, emmexx ha scritto:
> Il 11/05/2010 18:43, Francesco scrisse:
>> Hi,
>> I'm trying to display a popup on mouse over GPX track. This is the
>> code used to load the track:
>> onSelect: function(feature) {
>> --------------> Here I want to display a popup with info from the GPX file
>> onUnselect: function(feature) {
> I use eventListeners instead of onSelect onUnselect.
> bye
> maxx
>>>> Code for the popup:
> var highlightCtrl = new OpenLayers.Control.SelectFeature([vlayer,
> clayer], {
> hover: true,
> highlightOnly: true,
> multiple: true,
> eventListeners:
> featurehighlighted: function(f)
> popup = new OpenLayers.Popup("mylayer",
> f.feature.geometry.getBounds().getCenterLonLat(),
> null,
> 'some html text',
> null,
> true);
> popup.autoSize=true;
> // popup.panMapIfOutOfView=true;
> f.feature.popup = popup;
> featureunhighlighted: function(f)
> map.removePopup(f.feature.popup);
> f.feature.popup.destroy();
> f.feature.popup = null;
> map.addControl(highlightCtrl);
> highlightCtrl.activate();
> (popup is a global variable)
>>>>> Code to open a gpx file:
> var tmplayerGps= new OpenLayers.Layer.GML('myfile', path,
> format: OpenLayers.Format.GPX,
> formatOptions: {
> maxDepth: 2,
> 'styleMap': styleMap,
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100517/37e87aac/attachment.html
