[OpenLayers-Users] How to Use selectControl and dragFeature control at the same time?
Subhani Minhas subhaniminhas at gmail.com
Fri May 14 06:55:27 EDT 2010
Hurray, the code suggested by you works great :-)
Here is the final code which can achieve following:
1. Click to add a vector feature with custom icon and label at the point of
click (Completed)
2. Click to select any drawn feature and delete it (Completed)
3. Click to select any drawn feature and Modify it. ( By deleting and
re-creating the a new feature at the same place with new icon and label)
(Completed)
4. Drag Any selected or un-selected icon. (completed with the gracious help
of Mr. Ilya Braude, All credit goes to him)
My next goal is to save this layer  as kml. Hope i will post results soon
----------------the Code is as following- Sharing with every one in the hope
that sme one can benefit from it    -------------------------
<html xmlns="http://www.w3.org/1999/xhtml">
    <head>
        <title>OpenLayers Click Event Example</title>
        <link rel="stylesheet" href="../theme/default/style.css"
type="text/css" />
        <link rel="stylesheet" href="style.css" type="text/css" />
        <script src="../lib/OpenLayers.js"></script>
        <script type="text/javascript">
        var SHADOW_Z_INDEX = 10;
        var MARKER_Z_INDEX = 11;
        var DIAMETER = 200;
        var NUMBER_OF_FEATURES = 15;
        var selectedFeatureID = "None";
            var map,layer2, layer, selectedFeature, dragFeature,
selectControl  ;
            function init(){
                map = new OpenLayers.Map('map');
                var ol_wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
                    "http://labs.metacarta.com/wms/vmap0?", {layers:
'basic'} );
                var jpl_wms = new OpenLayers.Layer.WMS( "NASA Global
Mosaic",
                "http://t1.hypercube.telascience.org/cgi-bin/landsat7",
                {layers: "landsat7"});
                jpl_wms.setVisibility(false);
                map.addLayers([ol_wms, jpl_wms]);
                map.addControl(new OpenLayers.Control.LayerSwitcher());
                // map.setCenter(new OpenLayers.LonLat(0, 0), 0);
                map.zoomToMaxExtent();
         layer = new OpenLayers.Layer.Vector("Vector Layer 1", {
                styleMap: new OpenLayers.StyleMap({
                    "default": new
OpenLayers.Style(OpenLayers.Util.applyDefaults({
                        externalGraphic: "${icon}",
                  label : "${name}",
                        graphicOpacity: 1,
                  backgroundGraphic: "./marker_shadow.png",
                  graphicYOffset: -25, // shift graphic up 28 pixels
                        // Makes sure the background graphic is placed
correctly relative
                        // to the external graphic.
                        backgroundXOffset: -2,
                        backgroundYOffset: -20,
                        // Set the z-indexes of both graphics to make sure
the background
                        // graphics stay in the background (shadows on top
of markers looks
                        // odd; let's not do that).
                        graphicZIndex: MARKER_Z_INDEX,
                        backgroundGraphicZIndex: SHADOW_Z_INDEX,
                        pointRadius: 10
                    }, OpenLayers.Feature.Vector.style["default"])),
                    "select": new OpenLayers.Style({
                        //externalGraphic: "../img/marker-blue.png",
                  pointRadius: 15,
                  graphicYOffset: -35,
                        backgroundYOffset: -30
            map.addLayers([layer]);
            // Add a drag feature control to move features around.
            var dragFeature = new OpenLayers.Control.DragFeature(layer);
            map.addControl(dragFeature);
            dragFeature.activate();
//-------------Coe suggested by Mr Ilya Braude -------------
dragFeature.handlers['drag'].stopDown = false;
dragFeature.handlers['drag'].stopUp = false;
dragFeature.handlers['drag'].stopClick = false;
dragFeature.handlers['feature'].stopDown = false;
dragFeature.handlers['feature'].stopUp = false;
dragFeature.handlers['feature'].stopClick = false;
//-------------Coe suggested by Mr Ilya Braude-------------
                var click = new OpenLayers.Control.Click();
                map.addControl(click);
                click.activate();
        //vlayer = new OpenLayers.Layer.Vector( "Editable Vector Overlay" );
           //map.addLayer(vlayer);
        //map.addControl(new OpenLayers.Control.EditingToolbar(vlayer));
        selectControl = new OpenLayers.Control.SelectFeature(
                [layer],
                    clickout: true, toggle: false,
                    multiple: false, hover: false,
                    toggleKey: "ctrlKey", // ctrl key removes from selection
                    multipleKey: "shiftKey" // shift key adds to selection
            map.addControl(selectControl);
           selectControl.activate();
        layer.events.on({
                "featureselected": function(e) {
               var lonlat = map.getLonLatFromViewPortPx(e.xy);
                    showSelectedStatus(e.feature);
                "featureunselected": function(e) {
                    showUnSelectedStatus(e.feature);
         OpenLayers.Control.Click = OpenLayers.Class(OpenLayers.Control,
                defaultHandlerOptions: {
                    'single': true,
                    'double': false,
                    'pixelTolerance': 0,
                    'stopSingle': false,
                    'stopDouble': false
                initialize: function(options) {
                    this.handlerOptions = OpenLayers.Util.extend(
                        {}, this.defaultHandlerOptions
                    OpenLayers.Control.prototype.initialize.apply(
                        this, arguments
                    this.handler = new OpenLayers.Handler.Click(
                        this, {
                            'click': this.trigger
                        }, this.handlerOptions
                trigger: function(e) {
                  if (document.getElementById('pointToggle').checked ==
true)
              {     var lonlat = map.getLonLatFromViewPortPx(e.xy);
                var features = [];
                    var myMarker = new OpenLayers.Feature.Vector(new
OpenLayers.Geometry.Point(lonlat.lon , lonlat.lat));
                var MarkerLabel= document.getElementById("Marker
Label").value;
                var MarkerIcon= document.getElementById("Icon").value;
                myMarker.attributes = {
                                icon: "../img/" + MarkerIcon + ".png",
                                radius:10
                features.push(myMarker);
                layer.addFeatures(features);
      function showSelectedStatus(feature) {
         selectedFeature = feature;
               document.getElementById("status").innerHTML = "selected
feature "+feature.geometry.getBounds().getCenterLonLat() +" on Vector Layer
1";
    function showUnSelectedStatus(feature) {
            document.getElementById("status").innerHTML = "Un selected
feature "+feature.id+" on Vector Layer 1";
         selectedFeature = "None";
    function DelMarker()
 layer.removeFeatures(layer.selectedFeatures);
    function EditMarker()
    {    if ( selectedFeature != "None")
                var features = [];
OpenLayers.Geometry.Point(selectedFeature.geometry.getBounds().getCenterLonLat().lon
, selectedFeature.geometry.getBounds().getCenterLonLat().lat));
Label").value;
                                radius:10
//----------Nor being used really------------
    function toggleControl(element) {
            for(key in controls) {
                var control = controls[key];
                if(element.value == key && element.checked) {
                    control.activate();
                } else {
                    control.deactivate();
    </script>
    </head>
    <body onload="init()">
        <h1 id="title">Click Event Example with Custom Marker</h1>
        <div id="tags">
        </div>
        <p id="shortdesc">
            This example shows the use of the click handler and
getLonLatFromViewPortPx functions to trigger events on mouse click.It also
shows how to add a custom marker with custom Icon
        </p>
        <div id="map" class="smallmap"></div>
        <div id="docs">
                <input type="radio" name="type" value="none" id="noneToggle"
                       onclick="toggleControl(this);" checked="checked" />
                <label for="noneToggle">navigate</label>
                <input type="radio" name="type" value="point"
id="pointToggle" onclick="DrawFeratures();" />
                <label for="pointToggle">draw point</label>
            <label for="Marker Label"> -Label</label>
                <input id="Marker Label" type="text" size="5" maxlength="5"
                       name="Marker Label" value="label" onchange="update()"
         <label for="Icon">Icon</label>
            <select name="Icon" id="Icon">
                <option value="marker"
selected="selected">marker-red</option>
                <option value="marker-blue">marker-blue</option>
                <option value="marker-gold">marker-gold</option>
                <option value="marker-green">marker-green</option>
            </select>
        <button onclick="DelMarker();">Delete</button>
        <button onclick="EditMarker();">Edit</button><br />
        </div>
    <div id="status"></div>
    </body>
</html>
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100514/59c5e9c9/attachment.html
