[OpenLayers-Users] How to use Gauss Krueger JPEG with Open Layer?
Arnd Wippermann arnd.wippermann at web.de
Fri May 14 13:32:56 EDT 2010
Hello,
not that I'm aware. But images could be really large. 8000 x 4000 is no
problem. You have to wait a moment until the image is loaded, but afterwards
pan and zoom works lovely.
Regards,
Arnd
  _____
Von: Nicholas Efremov-Kendall [mailto:n.e.kendall at gmail.com]
Gesendet: Freitag, 14. Mai 2010 15:21
An: Arnd Wippermann
Cc: Marcel Ruff; users at openlayers.org
Betreff: Re: [OpenLayers-Users] How to use Gauss Krueger JPEG with Open
Layer?
Just for reference, is there a max size/resolution that can be used
optimally with the layer.image?
On Fri, May 14, 2010 at 4:14 PM, Arnd Wippermann <arnd.wippermann at web.de>
wrote:
If the size of the images are reasonable, then the easiest way is to use an
OpenLayers.Layer.Image.
Set the map with your Gauss-Krüger projection, add a baselayer and then your
image layers (with yourImgLayer.isBaseLayer=false). Or take the image layers
as baselayers.
http://openlayers.org/dev/examples/image-layer.html
Arnd
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Marcel Ruff
Gesendet: Freitag, 14. Mai 2010 11:08
An: users at openlayers.org
Betreff: [OpenLayers-Users] How to use Gauss Krueger JPEG with Open Layer?
I have some jpegs with Gauß Krüger projection.
How can I use those with Open Layers?
Thank you
Marcel
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
Users mailing list
Fulbright Student 2009-2010, Ukraine
nefremov at artsci.wustl.edu
c/o Halyna Yerko
Balzaka 92a, Kv 27
02232
Kyiv, Ukraine
(mob) +380963576524
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100514/bd0956c3/attachment.html
