[OpenLayers-Users] How to use Gauss Krueger JPEG with Open Layer?
Nicholas Efremov-Kendall n.e.kendall at gmail.com
Fri May 14 09:20:38 EDT 2010
Just for reference, is there a max size/resolution that can be used
optimally with the layer.image?
On Fri, May 14, 2010 at 4:14 PM, Arnd Wippermann <arnd.wippermann at web.de>wrote:
> Hi,
> If the size of the images are reasonable, then the easiest way is to use an
> OpenLayers.Layer.Image.
> Set the map with your Gauss-Krüger projection, add a baselayer and then
> your
> image layers (with yourImgLayer.isBaseLayer=false). Or take the image
> layers
> as baselayers.
> http://openlayers.org/dev/examples/image-layer.html
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von Marcel Ruff
> Gesendet: Freitag, 14. Mai 2010 11:08
> An: users at openlayers.org
> Betreff: [OpenLayers-Users] How to use Gauss Krueger JPEG with Open Layer?
> Hi,
> I have some jpegs with Gauß Krüger projection.
> How can I use those with Open Layers?
> Thank you
> Marcel
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
Fulbright Student 2009-2010, Ukraine
nefremov at artsci.wustl.edu
c/o Halyna Yerko
Balzaka 92a, Kv 27
02232
Kyiv, Ukraine
(mob) +380963576524
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100514/ab106f83/attachment.html
