[OpenLayers-Users] How to use Gauss Krueger JPEG with Open Layer?
Arnd Wippermann arnd.wippermann at web.de
Fri May 14 09:14:23 EDT 2010
If the size of the images are reasonable, then the easiest way is to use an
OpenLayers.Layer.Image.
Set the map with your Gauss-Krüger projection, add a baselayer and then your
image layers (with yourImgLayer.isBaseLayer=false). Or take the image layers
as baselayers.
http://openlayers.org/dev/examples/image-layer.html
Arnd
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Marcel Ruff
Gesendet: Freitag, 14. Mai 2010 11:08
An: users at openlayers.org
Betreff: [OpenLayers-Users] How to use Gauss Krueger JPEG with Open Layer?
I have some jpegs with Gauß Krüger projection.
How can I use those with Open Layers?
Thank you
Marcel
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
