[OpenLayers-Users] loading panel question
Chris Green chris.green at ibstv.co.uk
Fri May 21 04:02:10 EDT 2010
Hi list
I have been trying to make the loading panel work, as per
http://trac.openlayers.org/wiki/Addins/LoadingPanel but can't seem to make
it work.
I am using OL 2.8  (also tried 2.9 - same problem) which is referenced in my
code as:  <script src="../OpenLayers-2.8/lib/OpenLayers.js"></script>.
I downloaded LoadingPanel.js and put it in the directory
OpenLayers-2.8/lib/OpenLayers/Control.  Then when creating a map I have:
map = new OpenLayers.Map('map', options);
 var loadingpanel = new OpenLayers.Control.LoadingPanel()
                map.addControl(loadingpanel);
This throws an error in Firefox:  "OpenLayers.Control.LoadingPanel is not a
constructor"
The loading panel instructions talk about creating a single file build which
I have not done - is this my problem, or should I be able to make this work
with the OL 2.8  development libraries?
Chris
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100521/f525766b/attachment.html
