[OpenLayers-Users] loading panel question
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Fri May 21 04:04:57 EDT 2010
Hi Chris,
if you do it this way, you need to add an entry to your OpenLayers.js:
if(!singleFile) {
var jsfiles = new Array(
"OpenLayers/Control.js",
"OpenLayers/Control/LoadingPanel.js",
Best regards,
Bart
> Hi list
> I have been trying to make the loading panel work, as per
> http://trac.openlayers.org/wiki/Addins/LoadingPanel but can't seem to make
> it work.
> I am using OL 2.8 (also tried 2.9 - same problem) which is referenced in
> my
> code as: <script src="../OpenLayers-2.8/lib/OpenLayers.js"></script>.
> I downloaded LoadingPanel.js and put it in the directory
> OpenLayers-2.8/lib/OpenLayers/Control. Then when creating a map I have:
> map = new OpenLayers.Map('map', options);
> var loadingpanel = new OpenLayers.Control.LoadingPanel()
> map.addControl(loadingpanel);
> This throws an error in Firefox: "OpenLayers.Control.LoadingPanel is not
> a
> constructor"
> The loading panel instructions talk about creating a single file build
> which
> I have not done - is this my problem, or should I be able to make this
> work
> with the OL 2.8 development libraries?
> Chris
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
