[OpenLayers-Users] Layer from raster images...
Arnd Wippermann arnd.wippermann at web.de
Tue May 25 13:45:58 EDT 2010
Hi
As a workaround you could try with a point vectorlayer and externalGraphic.
With small images it works.
Problem is, when the insert point is outside the viewport, then the
externalGraphic will not displayed.
Example with nine images
http://gis.ibbeck.de/ginfo/apps/OLExamples/OL29/ExternalGraphicTilesLayer/Ex
ternalGraphicTilesLayer.asp
Arnd
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von paweluz
Gesendet: Montag, 24. Mai 2010 22:52
An: users at openlayers.org
Betreff: [OpenLayers-Users] Layer from raster images...
Hi!
It has been a while since I got any problems with OL but this time has
unfortunately come...
Actually I am just looking for some solution for my task...
I got some images that shows the city of New York with the streets hotels
and some other objects. All this data are stored as jpg files. I have images
of N.Y. in different scales e.g. 1:1000, 1:5000 and so on... So for example
I got 9 images of N.Y in scale 1:1000, 9 images in scale 1:2000 etc... I
have also got the center point of each picture. My task is to use them all
in openlayers. But I have to:
- presents not one picture on map but many pictures in some order. I mean
like this:
I have to glue them together using openlayers to preset the hole map of N.Y.
- I have to change all the images when someone changes the scale (zoom)
I was thinking about using the Image layer, but as far I know, one Image
layer does not allow to present many pictures... in url you define just the
string to url, and not the e.g table of images...
I know it is not standard question but maybe someone has any ideas... or
thoughts on this...
Any help would be appreciated
Regards
Poul
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Layer-from-raster-images-tp5095731p50
95731.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
