[OpenLayers-Users] SelectFeature working at the same time in two
different overlays?
Willy
gruppi at willygroup.org
Wed May 26 03:41:14 EDT 2010
I've two overlays, one is a Vector layers of markers built from a kml file,
the other is a GML geometric layer from an xml file.
I've added a SelectFeature for each layer, but if I add first layer1 then
layer2
only selectFeature for layer2 work. On otherwise if I add layer2 then layer1
only
selectFeature for layer1 work, there is a way to make working both layers?
Here the code:
var layer1 = new OpenLayers.Layer.Vector("Segnalazioni", {
'displayInLayerSwitcher':false,
styleMap: new OpenLayers.StyleMap(style),
projection: map.displayProjection,
strategies: [new OpenLayers.Strategy.Fixed()],
protocol: new OpenLayers.Protocol.HTTP({
url: "file.kml",
format: new OpenLayers.Format.KML({
extractStyles: false,
extractAttributes: true
var layer2 = new OpenLayers.Layer.GML(
"GML",
"file.xml",
styleMap: myStyleMap,
'isBaseLayer':false
selectControl = new OpenLayers.Control.SelectFeature(
layer2,
clickout: true, toggle: true,
multiple: false, hover: true
layer2.events.on(
"featureselected": function(e) {
alert("Selected.");
"featureunselected": function(e) {
alert("Unselected.");
map.addControl(selectControl);
selectControl.activate();
select = new OpenLayers.Control.SelectFeature(layer1);
layer1.events.on(
"featureselected": onFeatureSelect,
"featureunselected": onFeatureUnselect
map.addControl(select);
select.activate();
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100526/0807993f/attachment.html
