[OpenLayers-Users] ol+ags integration
Nathaniel Wingfield nw at UFL.EDU
Thu May 27 09:29:08 EDT 2010
Thanks to Andreas & Bryan for the pointers. I did eventually find
august's AGS work in
http://trac.openlayers.org/browser/sandbox/august/trunk/lib/OpenLayers/Control.
There appears to be support for Find, Identify, Query, Route,
Geoprocessing, and several other AGS functions. There also seems to be a
dependency on the ESRI JS API...
On 5/26/2010 3:05 PM, Andreas Hocevar wrote:
> Hi,
> have a look at
> http://openlayers.org/dev/examples/arcgis93rest.html
> and
> http://dev.openlayers.org/releases/OpenLayers-2.9.1/doc/apidocs/files/OpenLayers/Layer/ArcGIS93Rest-js.html
> This is all officially in the 2.9.1 release of OpenLayers.
> Regards,
> Andreas.
> On May 25, 2010, at 23:06 , Nathaniel Wingfield wrote:
>> I'm embarking on an ambitious project with ArcGIS Server and would like
>> to use OpenLayers for the front-end. I found some info
>> (http://www.mkgeomatics.com/apps/REST_Dev/) about adding identify&
>> geoprocessing support but the links to august's sandbox are dead and the
>> work has been removed from trac.openlayers.org. Is this a dead project
>> or has it graduated to something more official? Is there much going on
>> these days with OL + AGS integration?
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
