[OpenLayers-Users] GeoExt & OpenLayers, IE8 vs other Browsers
Andreas Hocevar ahocevar at opengeo.org
Wed May 26 09:33:12 EDT 2010
for Apache proxy to work you need the mod_proxy module.
More info can be found in the Apache documentation.
Regards,
Andreas.
On May 26, 2010, at 14:51 , Martin.L wrote:
> Thanks for the answers!
> @cd: My version is correctly. It makes a request to the WMS of the
> GeoServer. The params are optional.
> @Andreas: I've tried the second link and after I paste the code for the
> VitualHost-section, the Apache won't start again. The errormessage is "The
> requested operation has failed!". If I comment the VirtualHost-section,
> apache starts again. After that, I wanted to try the second link. I noticed
> that there is no path like /usr/lib/cgi-bin/ in my Apache-installation. So
> do you have some further informations for me?
> Here is the VitualHost-section in my httpd.conf
> <VirtualHost>
> ProxyRequest Off
> # Remember to turn the next line off if you are proxying to a
> NameVirtualHost
> ProxyPreserveHost On
> <Proxy>
> 	Order deny,allow
> 	Allow from all
> </Proxy>
> ProxyPass /geoserver http://localhost:8090/geoserver
> ProxyPassReverse /geoserver http://localhost:8090/geoserver
> </VirtualHost>
> Greets
> Martin
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/GeoExt-OpenLayers-IE8-vs-other-Browsers-tp5079946p5103295.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
