[OpenLayers-Users] First-time user of OpenLayers – FORMAT of Layers
BMcBride bmcbride at chacompanies.com
Thu May 27 11:27:18 EDT 2010
Hi Armin,
OpenLayers supports several different layer types.  Have a look at the
http://dev.openlayers.org/releases/OpenLayers-2.9.1/doc/apidocs/files/OpenLayers-js.html
Class Documentation  under the Layer section.  Depending on the size of your
raster layers, you may be able to load them directly as an Image Layer- see
http://openlayers.org/dev/examples/image-layer.html
http://openlayers.org/dev/examples/image-layer.html .  If they are large
images, you will probably want to cut them into tiles- see
http://www.maptiler.org/ Map Tiler .
The same general rule applies for your vector data.  Smaller, less complex
datasets may be loaded directly as a vector layer (KML, JSON, GML, Text,
etc), while larger datasets will require some server side processing.  You
could use GeoServer to render your files as WMS overlays in OpenLayers, or
you could load the data into a spatial database (PostGIS/MySQL) and write a
PHP script to call just the bits you need to fill the map viewport.
Hope this helps to get you started...
Bryan R. McBride, GISP
http://www.bryanmcbride.com bryanmcbride.com
View this message in context: http://osgeo-org.1803224.n2.nabble.com/First-time-user-of-OpenLayers-FORMAT-of-Layers-tp5109032p5109163.html
