[OpenLayers-Users] First-time user of OpenLayers ? FORMAT of
Layers (BMcBride)
Giuseppe Naponiello
beppenapo at gmail.com
Fri May 28 03:37:36 EDT 2010
> ... or you could load the data into a spatial database (PostGIS/MySQL) and
> write a
> PHP script to call just the bits you need to fill the map viewport.
> Hope this helps to get you started...
Very helpful, thanks!
I'm trying to do something like that but I don't understand how to perform
the script; I'll try to explain me better:
1. Extract the data from db with a query -> "select * from ..."
2. Create the variables
3. Write my html code and create a structure like a csv (first row as
title and then the data)
Could works?
bye
-beppe-
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100528/57a7549d/attachment.html
