[OpenLayers-Users] First-time user of OpenLayers ? FORMAT of Layers (BMcBride)
BMcBride bmcbride at chacompanies.com
Fri May 28 09:05:40 EDT 2010
There is a good PHP/MySQL tutorial written by the Google Geo Team you may
want to check out here:
http://code.google.com/apis/maps/articles/phpsqlajax.html
http://code.google.com/apis/maps/articles/phpsqlajax.html .
This method uses PHP to echo XML, but should get you started in the right
direction.  Keep in mind if you are storing spatial geometries you will need
to convert them to WKT using a function like AsText(the_geom).
Bryan R. McBride, GISP
http://www.bryanmcbride.com bryanmcbride.com
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Re-First-time-user-of-OpenLayers-FORMAT-of-Layers-BMcBride-tp5111964p5112983.html
