[OpenLayers-Users] WFS Not Returning Coordinates
Roald de Wit list at rdewit.net
Sat May 29 01:25:20 EDT 2010
Hi Blake,
You can work around this issue by providing the property names
explicitly in the options of your protocol, including the name of the
geometry.
Example:
     propertyNames:
'year,seq,name,storm_start,storm_end,msGeometry'.split(',')
Note that MapServer by default chooses 'msGeometry' as the name of the
geometry attribute even though it might be called 'the_geom' or
'wkb_geometry' on the data source. In your case it's 'location' I presume.
Regards, Roald
On 28/05/10 03:26, Arnd Wippermann wrote:
> Hi,
> If you use Mapserver 5.6.x, then it's a bug.
> WFS Server - GetFeature POST request does not return geometry
> http://trac.osgeo.org/mapserver/ticket/3235
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von Blake Crosby
> Gesendet: Donnerstag, 27. Mai 2010 16:36
> An: users at openlayers.org
> Betreff: [OpenLayers-Users] WFS Not Returning Coordinates
> Hello,
> I'm using WFS Protocol on a vector layer (as per the example) to plot data
> on the map from a wfs server:
> 	var geographic = new OpenLayers.Projection("EPSG:4326");
>                var layer = new OpenLayers.Layer.Vector("WFS", {
>                   strategies: [new OpenLayers.Strategy.BBOX()],
>                   protocol: new OpenLayers.Protocol.WFS({
>                   url:  "http://mapserver.worldflightplanner.com/radar/",
>                   featureType: "flightrules",
> 		featureNS: "http://mapserver.gis.umn.edu/mapserver",
> 		featurePrefix: "ms",
> 		version: "1.1.0",
> 		geometryName: "location",
> 		srsName: "EPSG:4326",
> 		extractAttribute: true
>           	}),projection: geographic
> This works fine, however, the returned GML from the WFS does not contain any
> coordinates, just the metadata. Is this something wrong with my Mapserver
> configuration, or my OL call?
> You can see the request, and the returned data here:
> http://pastebin.org/284683
> Thanks,
> Blake
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
