[OpenLayers-Users] WFS Not Returning Coordinates
Arnd Wippermann arnd.wippermann at web.de
Sun May 30 17:04:29 EDT 2010
Hi Roald,
Adding propertyNames (attributes of the feature) to the protocol solves the
problem with the geometry for MapServer 5.6.1. First I thought it wouldn't
work, because i added msgeometry instead of msGeometry. And I have to add
srsName to the protocol, what for version 5.2 is not needed.
thx
Arnd
-----Ursprüngliche Nachricht-----
Von: Roald de Wit [mailto:list at rdewit.net]
Gesendet: Samstag, 29. Mai 2010 07:25
An: 'Blake Crosby'
Cc: Arnd Wippermann; users at openlayers.org
Betreff: Re: [OpenLayers-Users] WFS Not Returning Coordinates
Hi Blake,
You can work around this issue by providing the property names explicitly in
the options of your protocol, including the name of the geometry.
Example:
     propertyNames:
'year,seq,name,storm_start,storm_end,msGeometry'.split(',')
Note that MapServer by default chooses 'msGeometry' as the name of the
geometry attribute even though it might be called 'the_geom' or
'wkb_geometry' on the data source. In your case it's 'location' I presume.
Regards, Roald
On 28/05/10 03:26, Arnd Wippermann wrote:
> Hi,
> If you use Mapserver 5.6.x, then it's a bug.
> WFS Server - GetFeature POST request does not return geometry
> http://trac.osgeo.org/mapserver/ticket/3235
> Arnd
> Von: users-bounces at openlayers.org
> [mailto:users-bounces at openlayers.org] Im Auftrag von Blake Crosby
> Gesendet: Donnerstag, 27. Mai 2010 16:36
> An: users at openlayers.org
> Betreff: [OpenLayers-Users] WFS Not Returning Coordinates
> Hello,
> I'm using WFS Protocol on a vector layer (as per the example) to plot
> data on the map from a wfs server:
> 	var geographic = new OpenLayers.Projection("EPSG:4326");
>                var layer = new OpenLayers.Layer.Vector("WFS", {
>                   strategies: [new OpenLayers.Strategy.BBOX()],
>                   protocol: new OpenLayers.Protocol.WFS({
>                   url:  "http://mapserver.worldflightplanner.com/radar/",
>                   featureType: "flightrules",
> 		featureNS: "http://mapserver.gis.umn.edu/mapserver",
> 		featurePrefix: "ms",
> 		version: "1.1.0",
> 		geometryName: "location",
> 		srsName: "EPSG:4326",
> 		extractAttribute: true
>           	}),projection: geographic
> This works fine, however, the returned GML from the WFS does not
> contain any coordinates, just the metadata. Is this something wrong
> with my Mapserver configuration, or my OL call?
> You can see the request, and the returned data here:
> http://pastebin.org/284683
> Thanks,
> Blake
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
