[OpenLayers-Users] SelectFeature and ModifyFeature
magiconair frank.schroeder at gmail.com
Wed Aug 3 12:54:07 EDT 2011
I have a map with two vector layers "*devices*", "*geofences*". The
"*devices*" layer contains features not modifiable by the user (e.g. a
circle for each device). The "*geofences*" layer contains polygons which the
user has created with the DrawFeature() control.
What I would like to do is the following:
1. Catch 'hover' events on 'devices' (e.g. for displaying a popup)
2. Allow the user to click on a polygon and immediately edit it
For that I have a *SelectFeature* control on the '*devices*' layer and a
*ModifyFeature* control on the *geofences* layer. However, it doesn't seem
to be possible to have them *both active at the same time*. When both
controls are active the 'hover' works but the 'edit feature' does not.
I've setup an example based on the select-feature-multilayer example under
this link.
Any help or insight is highly appreciated.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SelectFeature-and-ModifyFeature-tp6649428p6649428.html
