[OpenLayers-Users] SelectFeature and ModifyFeature
gbrun gbrun at myopera.com
Wed Aug 3 15:19:41 EDT 2011
Looking at this example, it seems possible to activate two controls at the
same time, but on the same layer for this example. You can try to create
each control separately and then activate them one after an other to make
them working at the same time!
http://openlayers.org/dev/examples/highlight-feature.html
I didn't try this, but it seems possible!
Geoffrey
Le Wed, 03 Aug 2011 18:54:07 +0200, magiconair <frank.schroeder at gmail.com>
a écrit:
> I have a map with two vector layers "*devices*", "*geofences*". The
> "*devices*" layer contains features not modifiable by the user (e.g. a
> circle for each device). The "*geofences*" layer contains polygons which
> the
> user has created with the DrawFeature() control.
> What I would like to do is the following:
> 1. Catch 'hover' events on 'devices' (e.g. for displaying a popup)
> 2. Allow the user to click on a polygon and immediately edit it
> For that I have a *SelectFeature* control on the '*devices*' layer and a
> *ModifyFeature* control on the *geofences* layer. However, it doesn't
> seem
> to be possible to have them *both active at the same time*. When both
> controls are active the 'hover' works but the 'edit feature' does not.
> I've setup an example based on the select-feature-multilayer example
> under
> this link.
> https://go-left.com/maptest/ol/examples/select-edit.html
> Any help or insight is highly appreciated.
> Thanks
> Frank
> http://osgeo-org.1803224.n2.nabble.com/SelectFeature-and-ModifyFeature-tp6649428p6649428.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
