[OpenLayers-Users] Re: marker can be created from feature?
ggarcia ggarcia at ihman.com
Thu Aug 4 05:33:05 EDT 2011
@JK
You are right man! The same happen to me.
I was looking to try to use OpenLayers.Feature and OpenLayers.Feature.Vector
to create a Marker because at first it look like the best practice:
1) You can tunning your marker
2) Adding Markers instead a Vector you get properly renders
If you wanna use OpenLayers.Feature:
1)
[CODE]
  var map_OpenLayers = new OpenLayers.Map("map");
  /* load your map */
  var map_markers= new OpenLayers.Layer.Markers( "Markers" );
  map_OpenLayers.addLayer(map_markers);
[/CODE]
2)
[CODE]
  var feature = new OpenLayers.Feature(map_markers, lonlat);
  feature.data.icon = new OpenLayers.Icon("img/light.png", new
OpenLayers.Size(53,59), new OpenLayers.Pixel(0,0));
  var marker = feature.createMarker();
  map_markers.addMarker(marker);
[/CODE]
If you wanna use OpenLayers.Feature.Vector:
"createMarker" returns null:
So if you know already how to solve this or someone is in a similar
situation and wanna comment, any help will be apreciated!
ggarcia
View this message in context: http://osgeo-org.1803224.n2.nabble.com/marker-can-be-created-from-feature-tp6451665p6651992.html
