AW: [OpenLayers-Users] Feature "style" and layer "styleMap"
gbrun gbrun at myopera.com
Wed Aug 31 02:31:01 EDT 2011
Just great! ^^
Thanks Arnd, your code works! It was a very good idea to enforce the
selectStyle of the selectControl! Thanks a lot!
Geoffrey
On Tue, 30 Aug 2011 19:07:29 +0200, gbrun <gbrun at myopera.com> wrote:
> Thanks for this reply! I tried to add a "select" style to the feature
> but it didn't work. I tried many ways, but unfortunately, the only way
> to style a feature is to put directly the style properties in the
> feature.style property like this (so without "select", or "default"):
> feature.style = {fillColor: #FFFFFF,
> 		strokeColor: #222222,
> But I didn't try exactly what you said, with the
> ctrlSelectFeature.selectStyle property. So I will try this tomorrow and
> come back to this thread to say if it works! This issue is not so
> important, it's only unpleasant for the user because once he has changed
> the feature color, he can't see if the feature is well selected when he
> is selecting it...
> Geoffrey
> Le Tue, 30 Aug 2011 18:53:08 +0200, Arnd Wippermann
> <arnd.wippermann at web.de> a écrit:
>> Hi,
>> I'm not sure, if it's possible to add a default and select style to a
>> feature.
>> But you can force the selectControl to use a select style of your
>> choice.
>> var selectStyle = OpenLayers.Util.extend({},
>> OpenLayers.Feature.Vector.style['select']);
>> ctrlSelectFeature.selectStyle=selectStyle;
>> Arnd
>> -----Ursprüngliche Nachricht-----
>> Von: openlayers-users-bounces at lists.osgeo.org
>> [mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von gbrun
>> Gesendet: Dienstag, 30. August 2011 10:23
>> An: openlayers-users at lists.osgeo.org
>> Betreff: [OpenLayers-Users] Feature "style" and layer "styleMap"
>> Hi everybody!
>> I've got a question about styles capabilities. I have a layer on which
>> users
>> can draw features. At this layers, I assigned a "styleMap" property.
>> When a user has finished drawing a polygon on this layer for example,
>> he can
>> select this one and change its color. For this, I use the "style"
>> property of the drawn feature. It works fine, but then, the "styleMap"
>> property of the layer doesn't apply at this feature anymore. This is a
>> problem, because the "styleMap" property defines a "select" style: this
>> one
>> doesn't concern the feature which had its color changed anymore. So the
>> user
>> can't see if he selected the feature or not! It seems that, if there is
>> a
>> style applied to a feature, the styleMap isn't taken into account for
>> this
>> feature anymore.
>> Does anyone know if there are some conflict between feature "style" and
>> layer "styleMap"?
>> Geoffrey
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Using Opera's revolutionary email client: http://www.opera.com/mail/
