[OpenLayers-Users] Re: adding KML file
Phil Scadden p.scadden at gns.cri.nz
Sun Feb 13 15:45:30 EST 2011
> Yes, I know, that kml file is too big, but I don't know, how I can make it
> lighter. I need to add some more kml files and one GeoTiff, I think, so it
> will be really bad, will not? Do you have some ideas, how I could do it
> better? But maybe it is another topic too.
So why is it KML at all? If this application has to be a web application
(and it sounds from earlier comments that perhaps it is actually meant
best as a local desktop), then you have to beat the problem of
minimising data transfer. Using a WMS server and converting the kml data
into a vector source that is mapping the WMS and queried by WFS is
better way to go. Geoserver (Opensource WMS and WFS server) can also
create KML on the fly from vector sources, appropriate to scale, for use
with google Earth if you want this as well.
Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St,
Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
