[OpenLayers-Users] Design suggestions for Interactive map!
Brent Fraser
bfraser at geoanalytic.com
Tue Jul 12 10:24:34 EDT 2011
Rob,
GeoMoose (http://www.geomoose.org/) is an OpenLayers based project
that supplies a complete (+/-) GUI, including a "Jump To" combobox and a
tabbed set of panels for displaying information. You may be able to get
some ideas from it...
Best Regards,
Brent Fraser
On 7/12/2011 7:07 AM, Robert Buckley wrote:
> Hi,
> I need some ideas on how to start a project using openlayers. The
> project entails a simple map which shows points. Each point has
> certain attributes (strings/integers)which correspond to locations in
> a town. My department would like a map which shows the individual
> attributes and the sum totals of the integer field listed in the
> attribute table beside the map when they are present in the map(ie
> BBOX strategy) or through a selection process(combo control?).
> eg. select town A from the comboBox -> the map zooms to the town
> bounds -> the statistics from the points present in that town are
> displayed in tabular form beside the map.
> Is this kind of thing do-able in an interactive way using postgis and
> geoserver, or should I be looked at static json lists?
> How /where should I start looking?
> If anyone has done similar work or has seen such maps i´d be grateful
> to see them,
> Yours,
> Rob
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110712/c57c2eb1/attachment.html
