[OpenLayers-Users] Re: Help with SLDSelect - not doing any highlighting.
Bart van den Eijnden bartvde at osgis.nl
Wed Mar 16 03:59:25 EDT 2011
Hi Phil,
I think it might help to ask on the Geoserver list why that SLD is not being applied properly. Maybe also Geoserver logging might give you a clue.
Using Mapserver I have always been using spatial filters in different spatial reference systems than the map, so this should not be an issue.
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On Mar 16, 2011, at 4:55 AM, Phil Scadden wrote:
> I am zero progress with this. Looking at the SLDSelect example, I note
> that layers are unprojected where my layers are projected (usually onto
> google). The polygon handler gets its coordinates in mercator. Do these
> have to projected into the native srs of the wms layer before supplying
> to the filter?
> Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St,
> Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
> Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
