[OpenLayers-Users] Using POI popups
    Marc Coevoet
    marcc at dommel.be
    Thu Mar 31 06:06:27 EDT 2011
Hello,
I only built two openlayer apps,
http://lijnhaltes.tk  (bus stops in Flanders/North Belgfium)
and
http://www.dxradio.byethost14.com/research/radio/fmmaps/
FM transmitters in some coutroies around Germany.
I have this source code for Openlayers and would like to add a Close Box
to the popups ...
<html xmlns="http://www.w3.org/1999/xhtml">
   <head>
     <style type="text/css">
#map {
         width: 100%;
         height: 100%;
         border: 0px;
         padding: 0px;
         position: absolute;
body {
         border: 0px;
         margin: 0px;
         padding: 0px;
         height: 100%;
     </style>
     <script src="http://www.openlayers.org/api/OpenLayers.js"></script>
     <script
src="http://www.openstreetmap.org/openlayers/OpenStreetMap.js"></script>
     <script type="text/javascript">
         // complex map object
         var map;
         // Start position for the map (hardcoded here for simplicity,
         // but maybe you want to get from URL params)
         var lat = 50.89517;
         var lon = 2.7206;
         var zoom = 7;
         function init(){
             map = new OpenLayers.Map('map',
                     { maxExtent: new
OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34),
                       numZoomLevels: 19,
                       maxResolution: 156543.0399,
                       units: 'm',
                       projection: new OpenLayers.Projection("EPSG:900913"),
                       displayProjection: new
OpenLayers.Projection("EPSG:4326")
             var layerMapnik = new OpenLayers.Layer.OSM.Mapnik("Mapnik");
             var layerTah = new
OpenLayers.Layer.OSM.Osmarender("Tiles at Home");
             map.addLayers([layerMapnik,layerTah]);
             var pois = new OpenLayers.Layer.Text( "My Points",
                     { location:"./textfile.txt",
                       projection: map.displayProjection
             map.addLayer(pois);
             map.addControl(new OpenLayers.Control.LayerSwitcher());
             var lonLat = new OpenLayers.LonLat(lon,
lat).transform(map.displayProjection,  map.projection);
             if (!map.getCenter()) map.setCenter (lonLat, zoom);
     </script>
   </head>
   <body onload="init()">
     <div id="map"></div>
   </body>
</html>
What's on Shortwave guide: choose an hour, go!
http://shortwave.tk
700+ Radio Stations on SW http://swstations.tk
300+ languages on SW http://radiolanguages.tk
