[OpenLayers-Users] Adjusting Zoom Level Based on Points
BalaVignesh Kasinathan kbalavignesh at gmail.com
Thu Nov 10 11:52:36 EST 2011
    I got solution based on Tac & Sveen reply. I have selected min and max
values of x & y from all points. And i set that as extent like follow,
 map.zoomToExtent(new OpenLayers.Bounds(minx,miny,maxx,maxy))
Thanks for the Solution.
Regards,
Bala
On Tue, Nov 8, 2011 at 7:35 PM, Sveen Atle Frenvik (Geomatikk IKT) <
Atle.Frenvik.Sveen at geomatikk.no> wrote:
> I guess something along these lines should do the trick (not tested)
> //create map etc..
> var vectorLayer = new OpenLayers.Layer.Vector("vectors");
> map.addLayer(vectorLayer);
> var draw = new
> OpenLayers.Control.DrawFeature(vectorLayer,OpenLayers.Handler.Path);
> map.addControl(draw);
> draw.events.register("featureadded",this,function(feature){map.zoomToExtent(feature.geometry.getBounds());});
> On 2011-11-08 14:55, Imran Rajjad wrote:
> if the points are in your vector layer, you can get the extent of that
> layer and set zoom accordingly
> On Tue, Nov 8, 2011 at 4:48 PM, Tac Tacelosky <tacman at gmail.com> wrote:
>> As you're going through the points, keep track of the min/max x and y,
>> then use those values to set the extent (the boundaries).
>>  While you can do this in Javascript, we ended up doing that calculation
>> in the server-side call that got the points, and sending it over with the
>> json that used to populate the array of points.
>>  Tac
>> On Tue, Nov 8, 2011 at 8:30 AM, BalaVignesh Kasinathan <
>> kbalavignesh at gmail.com> wrote:
>>> Hi,
>>>      I want to draw the line (route using x,y coordinate points) over
>>> the map as vector layer. After route drawn on map, i want to adjust the
>>> zoom level to show the complete route. How can i do this? Is there any
>>> direct way to do this? If not how to do using math calculations?
>>> Regards,
>>> Bala
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Users mailing list
> I.R
> Users mailing listUsers at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/openlayers-users
> Atle Frenvik Sveen
> Utvikler
> Geomatikk IKT AS
> tlf: 45 27 86 89atle.frenvik.sveen at geomatikk.no
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111110/0f730cad/attachment.html
