[OpenLayers-Users] Firefox 6 gives more errors than other browsers
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Wed Sep 21 20:28:10 EDT 2011
On Sep 21, 2011, at 5:56 PM, ext Mark K. Zanfardino wrote:
> I have run into a similar problem. Since I upgraded FF to 6.0.2 I am finding that I can not load the OpenLayers API uncompressed.  When I make a reference to OpenLayers/lib/OpenLayers.js I find that my page     fails to load and all references to OL returns an Undefined error in firebug console.  However, I can load the exact same page in IE or Chrome and everything works just fine.
> If I switch to using the compressed OpenLayers.js file everything works just fine as well. I'm stepping through the OpenLayers.js file to see if I can find anything specific to FF, but not knowing what I'm looking for is making this extremely time consuming.  If anyone else has run into this issue, please post your comments here.
> NOTE: I've tried this with OL 2.10 and 2.11 on IE8, IE9, Chrome, FF 3.6 and FF 6.0.2. My map pages loads in all browsers listed except FF 6.0.2
2.11 should work, are you sure it doesn't? can you set up a demo? This is one of the things we fixed in trunk around ~february.
-- Chris
> Cheers!
> Mark
> On 08/30/2011 03:57 AM, Robert Buckley wrote:
>> Hi,
>> After installing FF6 I have found that the error console is more active than before.
>> Mostly the first load of an app is ok, and then by refreshing the browser, an error comes, the second refresh gives even more errors. This is consistant!
>> Has anyone else found this?
>> yours,
>> Rob
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
