It seems, that with every click you create a new info control. So deactivate
works, but with the next click you activate a new control.
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von vrbikdan
Gesendet: Freitag, 6. April 2012 10:50
An: openlayers-users at lists.osgeo.org
Betreff: [OpenLayers-Users] wmsGetFeatureInfo deactivate button
I have really stupid question :) I have wmsGetFeatureInfo in my map and I
want to add checkbox for enable and disable this info. Enable works, but
disable don't and I don't know why. Maybe it could be better seen in code:
function onclck(){
	    info = new OpenLayers.Control.WMSGetFeatureInfo({
            url: "http://192.168.1.50:8080/geoserver/zk/wms",
            title: 'Identify features by clicking',
            queryVisible: true,
	    eventListeners: {
                getfeatureinfo: function(event) {
					 for (var i = 0; i <
event.features.length; i++) {
                       feature = event.features[i];
                       var attributes = feature.attributes;
					   x=attributes.fid;
					   for(var key in layers){
layers[key].mergeNewParams({env:"sel:"+x+";opacita:0.5"});}}}}});
			map.addControl(info);
             if
(document.forms.seznamVrstev.infoButt.checked){info.activate();}
             else{info.deactivate();}
This function I call on checkbox onclick. If I set info.deactivate(); out of
if/else it works, but I need to deactivate when is checkbox unchecked. And
when I try to set alerts in if/else, it works to, so I can't figure it out,
why deactivate doesn't work.
Is something I forgot? Thanks for help
Dan
View this message in context:
http://osgeo-org.1560.n6.nabble.com/wmsGetFeatureInfo-deactivate-button-tp46
92153p4692153.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
