[OpenLayers-Users] OpenLayers 2.11 renderer in Chrome
Fernando Norte fernando at globalgeo.com.br
Thu Apr 12 10:26:00 EDT 2012
Hi Jlindbergh,
I had some similar problems with Chrome and OpenLayers and realize that was
a deprecated Control features.
Check out what controls are you using.
Att,
2012/4/12 jlindbergh <jlindbergh at gmail.com>
> Hi!
> I came across a problem with the vector feature renderer in Chrome (SVG?).
> The problem is that when I resize the map, the vector features become
> misaligned. Both new and existing features. See screenshot:
> http://osgeo-org.1560.n6.nabble.com/file/n4853472/Chrome-screenshot.jpg
> I used the OpenLayers draw feature example to isolate the problem. The only
> thing I changed was to remove the width of the          .smallmap in
> style.css.
> After that you only need to do the following to reproduce:
> 1. Draw a feature.
> 2. Make the browser window smaller.
> It seems as it's only when the viewport becomes smaller than its initial
> size that the problem occurs. When making the window larger again, the
> features are aligned.
> Also I should mention that when switching back to OpenLayers 2.10 the
> problem goes away.
> Is this a known bug, and is there a recommended workaround?
> Best regards,
> /jlindbergh
> http://osgeo-org.1560.n6.nabble.com/OpenLayers-2-11-renderer-in-Chrome-tp4853472p4853472.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120412/d9ee73aa/attachment-0001.html
