[OpenLayers-Users] Layers on EPSG:3857 over Google Maps
Andreas Hocevar
ahocevar at opengeo.org
Wed Apr 18 14:05:36 EDT 2012
just configure
projection: "EPSG:3857"
in the WMS layer's options. GMaps v3 uses "EPSG:900913" by default.
Andreas.
2012/4/18 Luís de Sousa <luis.a.de.sousa at gmail.com>:
> Dear all,
> I'm trying to overlay some WMS layers on the Google Maps base layers. Both
> the map and the WMS layers are defined with the Sperical Mercator projection
> (EPSG:3857). But for some reason, all GetMap requests to the WMS overlays
> are modified by OpenLayers to the EPSG:900913 SRS. This is the same
> projection, but the server only knows the EPSG:3857 code.
> Is there a way I can prevent OpenLayers from modifying the request? Or some
> way to correct it before it is posted to the server?
> Thank you,
> Luís
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Layers-on-EPSG-3857-over-Google-Maps-tp4894411p4894411.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
