[OpenLayers-Users] Re: OpenLayers.Layer.Vector shifted in IE9 compatibility mode
Andreas Hocevar ahocevar at opengeo.org
Wed Apr 25 21:39:20 EDT 2012
Probably not the answer you want to hear, but don't use compatibility mode.
In standards mode, everything will work fine using the SVG renderer.
Andreas.
On Apr 25, 2012 1:07 PM, "Ricardo Bayley" <ricardo.bayley at gmail.com> wrote:
> I checked if styling has anything to do with it.
> If I dont set any styling, leave default style, then features get rendered
> properly.
> this is the styl I use
> * var style = function(){*
> * var defaultStyle = new OpenLayers.Style({*
> * cursor:"pointer",*
> * graphicHeight: "14" ,*
> * graphicWidth : "14",         *
> *        externalGraphic: "imgs/panoramio-marker.png",*
> *        graphicZIndex: 999*
> * selectStyle = new OpenLayers.Style({*
> * graphicZIndex: 1001,*
> * graphicHeight: "22",*
> * graphicWidth : "22"    *
> * myStyle = new OpenLayers.StyleMap({*
> * 'default': defaultStyle,*
> * 'select': selectStyle*
> *    return myStyle;*
> * app.panoramio.layer.styleMap = style();*
> FYI:* * panoramio-marker.png is a 18px X 18px png file.
> Any ideas ?
> ricardo
> 2012/4/25 Ricardo Bayley <ricardo.bayley at gmail.com>
>> Hi everyone,
>> I am trying to load Panoramios pictures. It works great on every browser
>> but in IE6, 7, 8 and IE9 compatibility mode features are not place properly.
>> Location is shifted. If I select any feature and show the popup, then
>> popup is shown in the correct X,Y location.
>> This is the code I user to load panoramios json to the
>> OpenLayers.Layer.Vector class
>> * var lyr = app.panoramio.layer, photo, feature, GeoJSON =
>> {"type":"FeatureCollection","total":data.photos.length,"features":[]}; *
>> * for(i=0; i < data.photos.length; i++){*
>> * photo = data.photos[i];*
>> * if(lyr.getFeaturesByAttribute("photo_id",photo.photo_id).length===0){*
>> * feature =
>> {"type":"Feature","geometry":{"type":"Point","coordinates":[photo.longitude,
>> photo.latitude]},"properties":photo};*
>> * GeoJSON.features.push(feature);  *
>> * // Reproject*
>> * var format = new OpenLayers.Format.GeoJSON({*
>> *        'internalProjection': new OpenLayers.Projection('EPSG:900913'),*
>> *        'externalProjection': new OpenLayers.Projection('EPSG:4326')*
>> * f = format.read(GeoJSON);*
>> * lyr.addFeatures(f);*
>> Any ideas why is this happening ? Is there a workaround ?
>> What I dont understand is I have other GeoJSON vector layers which load
>> correctly in every browser.
>> Could this have anything to do with styling ?
>> best regards,
>> Ricardo
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120425/6a5042ef/attachment.html
