[OpenLayers-Users] Re: OpenLayers.Layer.Vector shifted in IE9
compatibility mode
Ricardo Bayley
ricardo.bayley at gmail.com
Thu Apr 26 10:35:03 EDT 2012
Ok, but it also happens with IE6. Yet to try IE7 and 8.
2012/4/25 Andreas Hocevar <ahocevar at opengeo.org>
> Probably not the answer you want to hear, but don't use compatibility
> mode. In standards mode, everything will work fine using the SVG renderer.
> Andreas.
> On Apr 25, 2012 1:07 PM, "Ricardo Bayley" <ricardo.bayley at gmail.com>
> wrote:
>> I checked if styling has anything to do with it.
>> If I dont set any styling, leave default style, then features get
>> rendered properly.
>> this is the styl I use
>> * var style = function(){*
>> * var defaultStyle = new OpenLayers.Style({*
>> * cursor:"pointer",*
>> * graphicHeight: "14" ,*
>> * graphicWidth : "14", *
>> * externalGraphic: "imgs/panoramio-marker.png",*
>> * graphicZIndex: 999*
>> * selectStyle = new OpenLayers.Style({*
>> * graphicZIndex: 1001,*
>> * graphicHeight: "22",*
>> * graphicWidth : "22" *
>> * myStyle = new OpenLayers.StyleMap({*
>> * 'default': defaultStyle,*
>> * 'select': selectStyle*
>> * return myStyle;*
>> * app.panoramio.layer.styleMap = style();*
>> FYI:* * panoramio-marker.png is a 18px X 18px png file.
>> Any ideas ?
>> ricardo
>> 2012/4/25 Ricardo Bayley <ricardo.bayley at gmail.com>
>>> Hi everyone,
>>> I am trying to load Panoramios pictures. It works great on every browser
>>> but in IE6, 7, 8 and IE9 compatibility mode features are not place properly.
>>> Location is shifted. If I select any feature and show the popup, then
>>> popup is shown in the correct X,Y location.
>>> This is the code I user to load panoramios json to the
>>> OpenLayers.Layer.Vector class
>>> * var lyr = app.panoramio.layer, photo, feature, GeoJSON =
>>> {"type":"FeatureCollection","total":data.photos.length,"features":[]}; *
>>> * for(i=0; i < data.photos.length; i++){*
>>> * photo = data.photos[i];*
>>> * if(lyr.getFeaturesByAttribute("photo_id",photo.photo_id).length===0){*
>>> * feature =
>>> {"type":"Feature","geometry":{"type":"Point","coordinates":[photo.longitude,
>>> photo.latitude]},"properties":photo};*
>>> * GeoJSON.features.push(feature); *
>>> * // Reproject*
>>> * var format = new OpenLayers.Format.GeoJSON({*
>>> * 'internalProjection': new OpenLayers.Projection('EPSG:900913'),
>>> * 'externalProjection': new OpenLayers.Projection('EPSG:4326')*
>>> * f = format.read(GeoJSON);*
>>> * lyr.addFeatures(f);*
>>> Any ideas why is this happening ? Is there a workaround ?
>>> What I dont understand is I have other GeoJSON vector layers which load
>>> correctly in every browser.
>>> Could this have anything to do with styling ?
>>> best regards,
>>> Ricardo
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120426/acb38e79/attachment.html
