AW: [OpenLayers-Users] WMSCapabilities
Morper-Busch, Lucia Lucia.Morper-Busch at sbg.ac.at
Sat Apr 28 16:19:06 EDT 2012
After trying and searching finally I discovered the error!
The capabilities-XML of my Geoserver was corrupted! The xml structure was interrupted by the following ServiceExceptionReport:
<ServiceExceptionReport version="1.1.1" > <ServiceException>javax.xml.transform.TransformerException: Translator error Translator error Error occurred trying to write out metadata for layer: Pk50095 Unable to acquire a reader for this coverage with format: WorldImage</ServiceException></ServiceExceptionReport>
The xml-tags weren't closed. And so the document could not be read and parsed.
But the Pk50095-layer is an example layer of Geoserver, not added by me. That is very strange. Anyway, I deleted the layer, and the request gave me the desired response.
Lucia
Von: openlayers-users-bounces at lists.osgeo.org im Auftrag von Morper-Busch, Lucia
Gesendet: Fr 27.04.2012 17:18
An: openlayers-users at lists.osgeo.org
Betreff: [OpenLayers-Users] WMSCapabilities
Hello,
I want to read the WMS capability xml, in order to get the abstract and
the metadata link of each layer.
My code is:
var request = OpenLayers.Request.GET({
        url: url +
'?service=wms&version=1.1.1&format=text/xml&request=getcapabilities'
        ,success: function(response){
                //alert(response.responseText);
                var obj = new
OpenLayers.Format.WMSCapabilities.v1_1_1().read(response.responseText);
//var obj = new
OpenLayers.Format.WMSCapabilities().read(response.responseText);
                var capability = obj.capability;
                for (var i=0, len=capability.layers.length; i<len; i++)
                        var layerObj = capability.layers[i];
                        alert(layerObj.name);
The error is: "capability is undefined"
But "response.responseText" gives me the right xml as text.
"response.responseXML" is null.
response properties:
        _object: [object XMLHttpRequest]
        _listeners:
        _async: true
        readyState: 4
        responseXML: null
        statusText: OK
        status: 200
        priority: NORMAL
I use a proxy, that works fine for getFeatureInfo-Requests.
What is my problem?
Thank you
Lucia
Dipl.-Geogr. Lucia Morper-Busch | Researcher
University of Salzburg | Centre for Geoinformatics - Z_GIS
Schillerstr.30 | Techno-Z, Block 15, 3rd floor, Room 320 | 5020
Salzburg, Austria
Phone +43 (0)662 8044 5298 | Fax +43 (0)662 8044 5260
> Z_GIS...experts for the spatial view
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120428/097c1b47/attachment.html
