[OpenLayers-Users] Is any convertion required between GPS coordinate and Spherical Mercator projection?
Greg Allensworth
gregor at greeninfo.org
Fri Aug 3 06:45:34 PDT 2012
> I have GPS coordinate data in pure decimal GPS coordinate format for
> example 25.124167 in order to place the feature on the map. And I will
> use Google Maps layer with OpenLayers. Is any convertion required? Does
> OpenLayers implement in the background?
You will do coordinate conversion, yes. The map will use the Web
Mercator SRS -- to place a marker using WGS84, you would need to convert:
var SRS_GOOGLE = new OpenLayers.Projection("EPSG:900913");
var SRS_LONLAT = new OpenLayers.Projection("EPSG:4326");
var center = new OpenLayers.LonLat(-85.5678, 45.12345);
center.transform(SRS_LONLAT,SRS_GOOGLE);
map.setCenter(center, 10);
var box = new OpenLayers.Bounds(-122,43,-121,44);
box.transform(SRS_LONLAT,SRS_GOOGLE);
map.zoomToBounds(box);
If you forget to do this transform, then your coordinates will be very
close to the 0,0 mark at the equator & the Greenwich meridian (-85 and
45, in meters from 0,0). That's a great debugging tip: if your marker is
appearing at "practically 0,0" you probably are using "very tiny
coordinates" for your SRS.
Greg Allensworth, Web GIS Developer
BS A+ Network+ Security+ Linux+ Server+
GreenInfo Network - Information and Mapping in the Public Interest
564 Market Street, Suite 510 San Francisco CA 94104
PH: 415-979-0343 x302 FX: 415-979-0371 email: gregor at greeninfo.org
Web: www.GreenInfo.org www.MapsPortal.org
Subscribe to MapLines, our e-newsletter, at www.GreenInfo.org
