[OpenLayers-Users] GeoJson serialize and ModifyFeautre
Alexandre Dubé adube at mapgears.com
Fri Aug 3 08:38:08 PDT 2012
Hi Mark,
   Don't forget to include the list in CC so that others can see the
progression of your issue.
Regards,
Alexandre
On 12-08-03 11:25 AM, Mark Turek wrote:
> Hi Alexandre!
> Thank you for you answer. Attached you will find a little example program.
> Mark
> *From:* Alexandre Dubé <adube at mapgears.com>
> *To:* openlayers-users at lists.osgeo.org
> *Sent:* Friday, August 3, 2012 7:13 AM
> *Subject:* Re: [OpenLayers-Users] GeoJson serialize and ModifyFeautre
> Hi Mark,
>   Could you provide a minimized test case showing the problem then ?
> Pasting some code would be nice but sharing a live demo would be even
> better.
>   Here's a good "how to create a minimized test case" :
> http://docs.openlayers.org/help/minimize.html
> Regards,
> Alexandre
> On 12-08-02 10:28 PM, Mark Turek wrote:
>> I am using 2.12 version. Here is the problem I have.
>> If I draw a polygon, selecting it with ModifyFeature works fine. If I
>> serialize the layer features and then read them back in through
>> deserialization ModifyFeature never selects anything and stops working.
>> Serialization/Deserialization is done through OpenLayers.Format.GeoJSON.
>> Any clue what is happening?
>> Users mailing list
>> Users at lists.osgeo.org  <mailto:Users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Alexandre Dubé
> Mapgears
> www.mapgears.com  <http://www.mapgears.com/>
> Users mailing list
Alexandre Dubé
Mapgears
www.mapgears.com
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120803/ec949407/attachment.html>
