[OpenLayers-Users] GeoJson serialize and ModifyFeautre
Alexandre Dubé adube at mapgears.com
Fri Aug 3 08:46:57 PDT 2012
Hey Mark,
   I got something.  Instead of setting the vector layer features
property directly, use the addFeatures() method to add new features :
     //vectors.features = geojson.read(serialized);
     vectors.addFeatures(geojson.read(serialized));
   If you want to remove all current features first, call :
     vectors.removeAllFeatures();
HTH,
Alexandre
On 12-08-03 11:38 AM, Alexandre Dubé wrote:
> Hi Mark,
>   Don't forget to include the list in CC so that others can see the
> progression of your issue.
> Regards,
> Alexandre
> On 12-08-03 11:25 AM, Mark Turek wrote:
>> Hi Alexandre!
>> Thank you for you answer. Attached you will find a little example
>> program.
>> Mark
>> *From:* Alexandre Dubé <adube at mapgears.com>
>> *To:* openlayers-users at lists.osgeo.org
>> *Sent:* Friday, August 3, 2012 7:13 AM
>> *Subject:* Re: [OpenLayers-Users] GeoJson serialize and ModifyFeautre
>> Hi Mark,
>>   Could you provide a minimized test case showing the problem then ?
>> Pasting some code would be nice but sharing a live demo would be even
>> better.
>>   Here's a good "how to create a minimized test case" :
>> http://docs.openlayers.org/help/minimize.html
>> Regards,
>> Alexandre
>> On 12-08-02 10:28 PM, Mark Turek wrote:
>>> I am using 2.12 version. Here is the problem I have.
>>> If I draw a polygon, selecting it with ModifyFeature works fine. If
>>> I serialize the layer features and then read them back in through
>>> deserialization ModifyFeature never selects anything and stops working.
>>> Serialization/Deserialization is done through OpenLayers.Format.GeoJSON.
>>> Any clue what is happening?
>>> Users mailing list
>>> Users at lists.osgeo.org  <mailto:Users at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com  <http://www.mapgears.com/>
>> Users mailing list
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Users mailing list
Alexandre Dubé
Mapgears
www.mapgears.com
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120803/056e4f20/attachment.html>
