[OpenLayers-Users] Save feature
Alexandre Dubé adube at mapgears.com
Mon Aug 6 11:50:36 PDT 2012
   Here's an example [1] that shows how to setup a WFS-T protocol with a
vector layer and some editing tools.  It should give you a good idea
about what's required on client-side.
   Also, you'll need a server to manage your transactions to your
database.  If you currently don't have any, I'd propose the one I
usually use : TinyOWS.  It's light, easy to setup and connects easily to
a PostGIS data source.  Follow the installation instructions [2] and try
installing the demo as well (sudo make install-demo).
   The download url in the doc is invalid.  The good one is [3].
   This "how to" [3] should help a lot, too.
HTH,
Alexandre
[1] http://openlayers.org/dev/examples/wfs-protocol-transactions.html
[2] http://mapserver.org/trunk/tinyows/serverinstallation.html
[3] http://tinyows.org/release/tinyows-1.0.0.tar.bz2
[4] http://mapserver.org/trunk/tinyows/openlayershowtobasic.html
On 12-08-06 01:42 PM, adidas wrote:
> Hello! This example (
> http://openlayers.org/dev/examples/drag-feature.html ) shows how to
> draw a feature on the map. My question is: how to keep the drawn
> feature in the database?
> Thanks!
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Alexandre Dubé
Mapgears
www.mapgears.com
