[OpenLayers-Users] Save feature
adidas xkadidas at gmail.com
Mon Aug 6 12:58:48 PDT 2012
Thank you for your reply.
Is it possible to call the function, after I drew the feature (and this
function will getthe coordinates of the drawn feature)?
06.08.2012 21:50, Alexandre Dubé пишет:
> Hi,
> Here's an example [1] that shows how to setup a WFS-T protocol with a
> vector layer and some editing tools. It should give you a good idea
> about what's required on client-side.
> Also, you'll need a server to manage your transactions to your
> database. If you currently don't have any, I'd propose the one I
> usually use : TinyOWS. It's light, easy to setup and connects easily
> to a PostGIS data source. Follow the installation instructions [2] and
> try installing the demo as well (sudo make install-demo).
> The download url in the doc is invalid. The good one is [3].
> This "how to" [3] should help a lot, too.
> HTH,
> Alexandre
> [1] http://openlayers.org/dev/examples/wfs-protocol-transactions.html
> [2] http://mapserver.org/trunk/tinyows/serverinstallation.html
> [3] http://tinyows.org/release/tinyows-1.0.0.tar.bz2
> [4] http://mapserver.org/trunk/tinyows/openlayershowtobasic.html
> On 12-08-06 01:42 PM, adidas wrote:
>> Hello! This example (
>> http://openlayers.org/dev/examples/drag-feature.html ) shows how to
>> draw a feature on the map. My question is: how to keep the drawn
>> feature in the database?
>> Thanks!
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
