[OpenLayers-Users] Save feature
Alexandre Dubé adube at mapgears.com
Mon Aug 6 13:26:40 PDT 2012
Yes, it is. Let's say to use an OpenLayers.Control.DrawFeature control
to draw and add new features on the map, you could register an
'featureadded' on this control and commit accordingly.
HTH,
Alexandre
On 12-08-06 03:58 PM, adidas wrote:
> Thank you for your reply.
> Is it possible to call the function, after I drew the feature (and
> this function will getthe coordinates of the drawn feature)?
> 06.08.2012 21:50, Alexandre Dubé пишет:
>> Hi,
>> Here's an example [1] that shows how to setup a WFS-T protocol with a
>> vector layer and some editing tools. It should give you a good idea
>> about what's required on client-side.
>> Also, you'll need a server to manage your transactions to your
>> database. If you currently don't have any, I'd propose the one I
>> usually use : TinyOWS. It's light, easy to setup and connects easily
>> to a PostGIS data source. Follow the installation instructions [2]
>> and try installing the demo as well (sudo make install-demo).
>> The download url in the doc is invalid. The good one is [3].
>> This "how to" [3] should help a lot, too.
>> HTH,
>> Alexandre
>> [1] http://openlayers.org/dev/examples/wfs-protocol-transactions.html
>> [2] http://mapserver.org/trunk/tinyows/serverinstallation.html
>> [3] http://tinyows.org/release/tinyows-1.0.0.tar.bz2
>> [4] http://mapserver.org/trunk/tinyows/openlayershowtobasic.html
>> On 12-08-06 01:42 PM, adidas wrote:
>>> Hello! This example (
>>> http://openlayers.org/dev/examples/drag-feature.html ) shows how to
>>> draw a feature on the map. My question is: how to keep the drawn
>>> feature in the database?
>>> Thanks!
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
Alexandre Dubé
Mapgears
www.mapgears.com
