[OpenLayers-Users] OpenLayers.Geometry.LineString Problem
Yasemin YILMAZ
yasemin.yilmaz.embedded at gmail.com
Tue Aug 7 04:47:14 PDT 2012
Hi all,
I've drawn a line between two feature markers by using
OpenLayers.Geometry.LineString. A line from outline of a marker to other
has been drawn expectedly if the pen width is 1 as you can see in map1.png.
I want to use a bolder pen. But a line drawing starts from inside of a
marker unexpectedly if the pen width is 2 as you can see in map2.png. In
case 2, the line view turns to normal after I do some zoom out/in. How can
I solve this problem?
var mPoint1 = new OpenLayers.Geometry.Point(29, 41.060);
var mPoint2 = new OpenLayers.Geometry.Point(29, 41.100);
var mFeature1 = new OpenLayers.Feature.Vector(
mPoint1.transform(SRS_LONLAT, SRS_GOOGLE),
{ some: 'data'
externalGraphic: 'img/marker.png', graphicHeight: 21, graphicWidth: 16 });
var mFeature2 = new OpenLayers.Feature.Vector(
mPoint2.transform(SRS_LONLAT, SRS_GOOGLE),
{ some: 'data'
mVectorLayer.addFeatures(mFeature1);
mVectorLayer.addFeatures(mFeature2);
var mGeometry = new OpenLayers.Geometry.LineString([mPoint1,
mPoint2]);
var mArtery = new OpenLayers.Feature.Vector(mGeometry, null, {
strokeColor: "red",
strokeOpacity: 1,
strokeWidth: 2
mVectorLayer.addFeatures(mArtery);
Thanks a lot for your helps and explanations,
Yasemin
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120807/b912c37e/attachment-0001.html>
Type: application/rar
Desc: not available
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120807/b912c37e/attachment-0001.rar>
