[OpenLayers-Users] MapIgniter Project
Christian Ledermann christian.ledermann at gmail.com
Tue Aug 7 22:55:27 PDT 2012
and there is also another new kid on the block:
http://cartaro.org/
 The geospatial components used in Cartaro are PostGIS, GeoServer,
GeoWebCache and OpenLayers. All those are managed from within the
powerful CMS Drupal.
On Tue, Jul 31, 2012 at 3:24 PM, mafonso <mafonso333 at gmail.com> wrote:
> As I said, it is different in technology... and Mapserver + PHP should not
> be understimated :)
> Of course those platforms are much more mature which leaves out features
> comparison.
> Cheers,
> Marco
> 2012/7/31 Christian Ledermann [via OSGeo.org] <[hidden email]>
>> On Tue, Jul 31, 2012 at 2:40 PM, mafonso <[hidden email]> wrote:
>> > Thank you Christian for the enlightenment. I will check those projects
>> > and
>> > extract a detailed comparison.
>> > At a first sight, Plone is based on Python.
>> and on the zope framework.
>> > GeoNode is based on Java.
>> actually it is a mix of django (python), postgis,  geoserver.  geonetwork
>> (java)
>> > CartoDB is limited on Free Plan.
>> Cartodb is mainly build on Ruby, Nodejs, Postgis
>> It is not obvious from their man page but it is open source
>> https://github.com/Vizzuality/cartodb
>> > MapIgniter is based on PHP, Open Source,
>> all of the above are open soure too.
>> Best Regards,
>> Christian Ledermann
>> Nairobi - Kenya
>> Mobile : <a href="tel:%2B254%20702978914" value="+254702978914"
>> target="_blank">+254 702978914
>> If you save the living environment, the biodiversity that we have left,
>> you will also automatically save the physical environment, too. But If
>> you only save the physical environment, you will ultimately lose both.
>> 1) Don’t drive species to extinction
>> 2) Don’t destroy a habitat that species rely on.
>> 3) Don’t change the climate in ways that will result in the above.
>> Users mailing list
>> [hidden email]
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.n6.nabble.com/MapIgniter-Project-tp4991898p4992111.html
>> To unsubscribe from MapIgniter Project, click here.
>> NAML
> View this message in context: Re: MapIgniter Project
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
Best Regards,
Christian Ledermann
Nairobi - Kenya
Mobile : +254 702978914
