[OpenLayers-Users] MapIgniter Project
Marco Afonso mafonso333 at gmail.com
Wed Aug 8 04:43:23 PDT 2012
Seems cool! Good for Geoserver... it looks strange inside Drupal's
interface...
Well... MapIgniter GeoCMS uses MapServer so maybe can fill a gap here.
Although MapServer also supports SLD, it seems to me that feature styling
is easier with MapIgniter. I will make a specific video about that later...
Cheers,
Marco
2012/8/8 Christian Ledermann [via OSGeo.org] <
ml-node+s1560n4993792h65 at n6.nabble.com>
> and there is also another new kid on the block:
> http://cartaro.org/
>  The geospatial components used in Cartaro are PostGIS, GeoServer,
> GeoWebCache and OpenLayers. All those are managed from within the
> powerful CMS Drupal.
> On Tue, Jul 31, 2012 at 3:24 PM, mafonso <[hidden email]<http://user/SendEmail.jtp?type=node&node=4993792&i=0>>
> wrote:
> > As I said, it is different in technology... and Mapserver + PHP should
> not
> > be understimated :)
> > Of course those platforms are much more mature which leaves out features
> > comparison.
> > Cheers,
> > Marco
> > 2012/7/31 Christian Ledermann [via OSGeo.org] <[hidden email]>
> >> On Tue, Jul 31, 2012 at 2:40 PM, mafonso <[hidden email]> wrote:
> >> > Thank you Christian for the enlightenment. I will check those
> projects
> >> > and
> >> > extract a detailed comparison.
> >> > At a first sight, Plone is based on Python.
> >> and on the zope framework.
> >> > GeoNode is based on Java.
> >> actually it is a mix of django (python), postgis,  geoserver.
>  geonetwork
> >> (java)
> >> > CartoDB is limited on Free Plan.
> >> Cartodb is mainly build on Ruby, Nodejs, Postgis
> >> It is not obvious from their man page but it is open source
> >> https://github.com/Vizzuality/cartodb
> >> > MapIgniter is based on PHP, Open Source,
> >> all of the above are open soure too.
> >> Best Regards,
> >> Christian Ledermann
> >> Nairobi - Kenya
> >> Mobile : <a href="tel:%2B254%20702978914" value="+254702978914"
> >> target="_blank">+254 702978914
> >> If you save the living environment, the biodiversity that we have left,
> >> you will also automatically save the physical environment, too. But If
> >> you only save the physical environment, you will ultimately lose both.
> >> 1) Don’t drive species to extinction
> >> 2) Don’t destroy a habitat that species rely on.
> >> 3) Don’t change the climate in ways that will result in the above.
> >> _______________________________________________
> >> Users mailing list
> >> [hidden email]
> >> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> >> If you reply to this email, your message will be added to the
> discussion
> >> below:
> http://osgeo-org.1560.n6.nabble.com/MapIgniter-Project-tp4991898p4992111.html
> >> To unsubscribe from MapIgniter Project, click here.
> >> NAML
> > View this message in context: Re: MapIgniter Project
> > Sent from the OpenLayers Users mailing list archive at Nabble.com.
> > Users mailing list
> > [hidden email] <http://user/SendEmail.jtp?type=node&node=4993792&i=1>
> Best Regards,
> Christian Ledermann
> Nairobi - Kenya
> Mobile : +254 702978914
> Users mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=4993792&i=2>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/MapIgniter-Project-tp4991898p4993792.html
>  To unsubscribe from MapIgniter Project, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4991898&code=bWFmb25zbzMzM0BnbWFpbC5jb218NDk5MTg5OHwtMzgyNzU4ODQz>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120808/40de8700/attachment-0001.html>
