[OpenLayers-Users] MapIgniter Project and other geospatial CMS
uli uli.mueller at gmx.ch
Thu Aug 9 01:06:58 PDT 2012
Hi
we at geOps are the people behind the "new kid on the block" Cartaro.
Cartaro is still a young project with incomplete documentation, and that
is why we have not promoted it intensively so far. Let me just make a
short note about the "gap" we want to fill with Cartaro. First Cartaro
does not reinvent any wheels. In the opposite Cartaro builds on some of
the most powerful OS projects available in the fields of CMS *and* GIS,
namely Drupal, PostGIS, GeoServer and Openlayers. Carataro "simply" does
the integration of these projects into a software stack that can form
the basis as well for a small website with some geodata as for a large
geospatial project (let's call the latter "lightweight SDI"). So the
focus goes far beyond the "collective mapping" aspect. With this said
Cartaro seems to be unique among the projects named in this thread, it
integrates either more of existing CMS (as compared to mapigniter,
GeoNode, CartoDB) or more of existing GIS software (as compared to
collective.geo and CartoDB).
Who wants to stay tuned to Cartaro can follow @CartaroORG or
planet.osgeo.org, where we will publish all relevant news on the project.
Cheers, Uli
geOps e.K.
Handelsregister A 702785, Amtsgericht Freiburg
NEU: Kaiser-Joseph-Strasse 263
D-79098 Freiburg
fon     +49 761 503 126 91
fax     +49 761 503 126 94
free service calls from D and CH
      00800 436 436 436
web www.geops.de
rss www.geops.de/blog/feed
follow www.twitter.com/geops_tweet
Am 08/08/2012 01:43 PM, schrieb Marco Afonso:
> Seems cool! Good for Geoserver... it looks strange inside Drupal's
> interface...
> Well... MapIgniter GeoCMS uses MapServer so maybe can fill a gap here.
> Although MapServer also supports SLD, it seems to me that feature
> styling is easier with MapIgniter. I will make a specific video about
> that later...
> Cheers,
> Marco
> 2012/8/8 Christian Ledermann [via OSGeo.org]
> <ml-node+s1560n4993792h65 at n6.nabble.com
> <mailto:ml-node+s1560n4993792h65 at n6.nabble.com>>
>     and there is also another new kid on the block:
>     http://cartaro.org/
>      The geospatial components used in Cartaro are PostGIS, GeoServer,
>     GeoWebCache and OpenLayers. All those are managed from within the
>     powerful CMS Drupal.
>     On Tue, Jul 31, 2012 at 3:24 PM, mafonso <[hidden email]
>     <http://user/SendEmail.jtp?type=node&node=4993792&i=0>> wrote:
>     > As I said, it is different in technology... and Mapserver + PHP
>     should not
>     > be understimated :)
>     > Of course those platforms are much more mature which leaves out
>     features
>     > comparison.
>     > Cheers,
>     > Marco
>     > 2012/7/31 Christian Ledermann [via OSGeo.org] <[hidden email]>
>     >> On Tue, Jul 31, 2012 at 2:40 PM, mafonso <[hidden email]> wrote:
>     >> > Thank you Christian for the enlightenment. I will check those
>     projects
>     >> > and
>     >> > extract a detailed comparison.
>     >> > At a first sight, Plone is based on Python.
>     >> and on the zope framework.
>     >> > GeoNode is based on Java.
>     >> actually it is a mix of django (python), postgis,  geoserver.
>      geonetwork
>     >> (java)
>     >> > CartoDB is limited on Free Plan.
>     >> Cartodb is mainly build on Ruby, Nodejs, Postgis
>     >> It is not obvious from their man page but it is open source
>     >> https://github.com/Vizzuality/cartodb
>     >> > MapIgniter is based on PHP, Open Source,
>     >> all of the above are open soure too.
>     >> Best Regards,
>     >> Christian Ledermann
>     >> Nairobi - Kenya
>     >> Mobile : <a href="tel:%2B254%20702978914" value="+254702978914
>     <tel:%2B254702978914>"
>     >> target="_blank">+254 702978914 <tel:%2B254%20702978914>
>     >> If you save the living environment, the biodiversity that we
>     have left,
>     >> you will also automatically save the physical environment, too.
>     But If
>     >> you only save the physical environment, you will ultimately
>     lose both.
>     >> 1) Don't drive species to extinction
>     >> 2) Don't destroy a habitat that species rely on.
>     >> 3) Don't change the climate in ways that will result in the above.
>     >> _______________________________________________
>     >> Users mailing list
>     >> [hidden email]
>     >> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>     >> If you reply to this email, your message will be added to the
>     discussion
>     >> below:
>     http://osgeo-org.1560.n6.nabble.com/MapIgniter-Project-tp4991898p4992111.html
>     >> To unsubscribe from MapIgniter Project, click here.
>     >> NAML
>     > View this message in context: Re: MapIgniter Project
>     > Sent from the OpenLayers Users mailing list archive at Nabble.com.
>     > Users mailing list
>     > [hidden email]
>     <http://user/SendEmail.jtp?type=node&node=4993792&i=1>
>     Best Regards,
>     Christian Ledermann
>     Nairobi - Kenya
>     Mobile : +254 702978914 <tel:%2B254%20702978914>
>     If you save the living environment, the biodiversity that we have
>     left,
>     But If
>     you only save the physical environment, you will ultimately lose
>     both.
>     Users mailing list
>     [hidden email] <http://user/SendEmail.jtp?type=node&node=4993792&i=2>
>     discussion below:
>     http://osgeo-org.1560.n6.nabble.com/MapIgniter-Project-tp4991898p4993792.html
>     <http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4991898&code=bWFmb25zbzMzM0BnbWFpbC5jb218NDk5MTg5OHwtMzgyNzU4ODQz>.
>     NAML
>     <http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> Users mailing list
> Users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120809/8a4e0e9d/attachment-0001.html>
